so i did the tps adjustment and i like the improved slow speed ridability. a couple things i noticed though. i used the instructions from here
http://forums.sv650.org/showthread.php?t=55459&highlight=throttle+position+sensor
but my 09 has a different tps that is black, has 1 screw and the plug faces the rear. adjustment was the same. also i have no idle adjustment screw like the one posted on my bike.
Just so you know, 07+ have IAC solenoid, no screw. They always idle at 1300 because you can't adjust it. If it's anything but 1300 warmed up, you have a problem. Your 05 should also idle at 1300 +/- 100, but you have a screw on the side to adjust that.
