Ok so I was doing the LSL swap today to convert my S model to bars and when I turn to full lock the throttle sticks. I re routed the cables through the frame but they still stick at full lock. Any ideas?
Try readjusting the pull or the push cables while in the full lock position... mine (well my old 99) did that too a little untill I got the adjustment just right after I put on the R6 throttle... (Granted I didn't do a naked/s conversion)
I had to slack one off a touch and tighten the other a bit... baring that... try a good lube in the cable and work it in while in the lock position...
Are your cables appropriately sized for the conversion? they may be pinching somewhere at full lock... or pulling at an odd angle
