I'm almost done with the first phase of this project which was to make it road worthy. Just an oil change and speed sensor (pickup) to go. When I fixed my coolant leak on the last post I rushed putting it back together and forgot I had removed the rectifier and had not bolted it back in properly. So back apart things went.
As you can see having the proper tools for the job makes life so much easier. lol
I had completely removed the pair system as part of this project. The actuator in the airbox didn't need to be removed but since I had the little gizmo that fooled the system into thinking the system was normal I decided to ditch it. I mentioned being a packrat before and I found a plug that fit perfectly for the airbox.
I'm a packrat, not a hoarder. The majority of this stuff is now in the trash but it put into prospective the scale of refreshing an old SV and what may need to be looked at on an older machine. It also made for a cool photo op.
