1 - 13 of 13 Posts
Hello everyone, I don't want to beat the already extra beatten horse but I got a question, that might interest others. What is the correct oil level? I found many opinions about this, including one from the FAQ Tips and Tricks: I'll try to quote the thread starter : Oil level must be BETWEEN the Low and Full marks - between as in the middle? Some people recommend that the oil should be at the Full mark, some between the L/F marks. So...what is the correct one? As far as I kno the oil level might influence the shifting of the gears, but I don't want to lack the motor of oil.:eek:ccasion14:
Too much oil makes shifting more difficult. Too little is bad for the bike. Fill to between the lines. I aim for half way between
Pour oil into the filler, 2.4 US qt, 2.0 imp qt, or 2.3 liters. Start the bike and run it a few minutes. Turn it off and holding the bike level, check the oil level in the sight glass on the right side of the engine. If it's above full, drain a bit out, if below low, add a bit more.
Someone mentioned its bad to keep the level below the max line for some reason... They sounded knowledgeable about it... I think you should start with MAX line and hope your bike does not eat oil... Mine does not. I keep it for 5-6k miles but I use synthetic Rotella...
My '01 is 11yrs old and the oil level was always in the middle, not at max and my motor is still going strong, owned by another using dino oil.
Rotella T, nuff said
If you use the quantity of oil recommended in the Owner's Manual the oil will be at the full mark. If you don't measure, it's a tedious task of trial and error.
I measure my oil in a 1 litre beaker (100CC graduations) and when measuring the correct amount, the oil is at the full mark. Right where I want it. Not too much, not too little.
Amazing.
just like a dipstick in a car
anywhere between high and low is full
My service manual states:
Place the motorcycle on level ground and hold it in an upright position. Check the oil level in the oil level sight glass. If the oil level is below the "L" mark, add oil until the oil level is at the "F" mark.
Is this an oil thread?.... my oh my...
What does "between" mean? It's not that difficult, really.
1 - 13 of 13 Posts
