Just curious.
Not to keen on the o-ring trick as there is too much a gap between the grip and end weight.
Any throttle locks out there that work?
On my ducati I had a hole drilled in the cable housing that was tapped with a screw in it. You could put drag on the throttle by running that screw in a little bit. Anyone try this?
