Overwhelmingly positive. Do it.
One note: I go over in this video, that doing the R/R-direct-to-battery-wiring mod can probably save you from needing an R/R upgrade in the first place.
My old stock, and new '02 GSX-R1000 SCR-type R/Rs, when hooked up to the stock output connectors in the wiring harness, got shockingly hot -- I didn't shoot it with a laser pyrometer (should get one), but both got so hot after only five or so seconds, that I couldn't keep my fingers pressed to them. The GSX-R one, when modded to use the harness, got so hot on a typical commute (12 miles at highway speeds), that I could feel its heat radiating, just putting my hand on the tail section plastic.
Once I did the 12ga direct wiring mod, though... output measured at the terminals became both more consistent and higher-output, plus... the R/R body barely registers any warmth on the fingertips. The video says it all.
Here is D'Ecosse's comprehensive post on another forum for the wiring and R/R mods...
You may not *need* a MOSFET (Metal-Oxide Semiconductor Field-Effect-Transistor) R/R, if you spend the $5 - $6 and 45 mins to do this mod. But if you want a reliability upgrade, or your R/R just $hit the bed, do yourself a favor and get a FET R/R (the 50A FH012AA, or the 35A FH010BA*, what I got.
EDIT: D'Ecosse below states that the FH010, and possibly even the FH008 {best for 1gens}, *may* be 40A - 50A units according to Shindengen... stay tuned as he has emailed the company for definitive output specs.) Then get Eastern Beaver's direct-to-battery wiring adapter kit for the FHs, very high-quality for the price, and bolt-on as well.
They're the same price or only a bit more to get a superior FET R/R vs. a Suzuki or early Honda SCR R/R. Why even consider anything else... any questions on the vid or of me, shoot.
* OEM, '06 Kawasaki ZX-10R.
