1 - 17 of 17 Posts
· Registered
I assume they're just a big 'sticker' as far as applying them?
Well, sort of. TS uses a very cool 3M adhesive that can be reused, unlike Stomp Grip or some others. But this stuff requires heating them up first (and the tank surface) with a hairdrier to activate the adhesive.
It took all of 15 minutes to install mine, and I love 'em. No more nut-crushing under hard braking now. LOL ;)
Also, they really help take stress off the lower back & wrists, as you can use your legs more to support your weight. Be forewarned, the first few times you ride, you can expect sore thighs with the 'workout' you'll give to them. :D
· Registered
... Be forewarned, the first few times you ride, you can expect sore thighs with the 'workout' you'll give to them. :D
+1
or when you don't ride for a while... like over the winter break and then get back on :p
WCJ,
no need to make larger pics, those are large enough :)
Here's mine on my 05 Yellow
you'll notice that they're quite off center and not level ;D
I'm too lazy to take them back off and recenter realign them... they still work, so I'm just gonna leef it.
· Registered
So about having to warm it up... I know the directions said 80*. It was more like 60* in my garage and it seems to adhere just fine. I had to reapply one side and it took a good deal of tugging to get just the 1/2 pad that I stuck on to come loose. Should I hit it with a hair dryer anyways or just let the Texas heat "activate" the adhesive?
Im quite the retentive type so I needed to get it as symmetrical as possible within the time constraints allotted to complete the task.
· Registered
There's usually a banner ad at the top of the site you can click on. Or you can go to http://www.techspec-usa.com/.
Ah, thanks for the link. (I run ad-block in firefox, so I don't see most banners...)
Good to hear about the heat-applied adhesive thing. That's what I'd be looking for, I'd hate to wind up not liking them, and then having to deal with glue residue everywhere if I took them off....I'll definitely have to look into these.
· Registered
I'm about to order these. I was wondering which was the better (Snake Skin, High Fusion)? Does the Snake Skin come beveled at the edges to keep them from looking too much like a ridge at the edges? My new Gel Seat seems to be more slippery than the stock seat was and I've noticed the effect more on my wrists during longer rides. Definitely need to make this my next purchase.
· Registered
-1.
stomp grip uses 3M as well. i've removed my stomp grips 2x 6 months ago, and before i had it painted a month ago and reapplied after paint....they've held up fine and haven't slipped.
wcj i like the color scheme.
· Registered
I put my Tech-Spec High Fusion pads on a couple of weeks back. Doing a lot of 2-up riding I have found them invaluable when braking. They are also great to keep my weight off my wrists by squeezing my knees into the tank and using torso muscles for support especially around town.
1 - 17 of 17 Posts
