I found when I fitted the GSXR front (SRAD yokes, K2 forks and clipons) that the bars are too low and cause clearance prblems with the cables- it's marginal, but annoying. After a bit of hunting around I've found that '00-04 Fireblade clipons fit without much modification (you need to grind one small part off) and give you about an inch, inch and a half of additional height. They're slightly narrower than stock, so not perfect, but as cheap fixes go I'm pretty happy with them. You lose the small bolt that secures the bar to the yokes but that's common with aftermarket clipons anyway.
I might still get a set of Sun Risers, but this is way cheaper...
Now why, when I asked that last month, did nobody tell me? :) I spent ages sniffing around the bike dealerships but there were no TLs of either stripe. Good to know though.
Thr Blade clipons would be a little taller than the SV ones, so if you want a bit mroe tey might still be a good option... But it sounds like I'll be looking for TL bits :)
