1 - 4 of 4 Posts
I went to take out the headlight on my '03 naked, but after taking out the 2 bolts, when I went to pull it out it was still attached at the top-leftish somehow. I didn't want to force it, but did I miss something or is there a trick to getting it off? Thanks.
The naked headlight? Are you referring to the 2 screws that are around the chrome ring? If so, then I think you just need to turn the chrome ring counter-clockwise a little, and everything should come apart. That is, if it's that same as the 1st gen headlight.
There is a little tab, about an inch wide, in the top left, just work it a little or rotate and it will come out.
1 - 4 of 4 Posts
