the bike i just got was a former track bike. it had no rear seat, gauges and nothing under the tail (turn signals or licence plate mount). the guy gave me a plate mount to a honda by accident. there are three wires with little square plugs (one white, one gray, and one black) at the front of the rear seat. what are these supposed to go to?
one is left turn, one is right turn and the other is the tag light.
i forgot exactly which is which. im pretty sure the white one is the tag light. to check them, you can either plug the lights in, start playing with the switches and ign key(for the tag light), or use a test light and turn a signal on and poke each one and figure out which is which.
shouldnt be too bad. you can probably source the connectors from someone converting their bike from street to track, and then whatever lights you choose.
or, you dont even absolutely need the connectors. just cut the connectors from the harness(figure out which is which first, though) and just splice the wires or even splice in your own connectors.
simple electrical like this isnt black magic or anything ;D:eek:ccasion14:
EDIT--also, just to make sure, is there a more flat, white conector? i think like two, maybe three wires? thats for the actual tail light assembly.
