I've got a 2005 SVS that currently has Heli Bars. I'm starting a project where I'll swap those bars for a set of 3.5" rise Swatt's and drag bars (cut in half). What I'm wanting to end up with is essentially the same hand placement in space, but with my hands at more of a downward angle (to the outside) so I can relax my elbows a whole lot more. Kind of a high cafe hand position, if you will. I haven't taken anything apart yet, I've just cut the drag bars and put them in the Swatt clamps, then put them up against the fork to test the placement.
What I noticed is the bolt that clamps the forks into the top triple... Seems like the riser on the Swatt clip would hit that bolt. Here's a diagram of the top triple:
So, for those of you that have the Swatts... Does this pose a problem? Or am I tilting at windmills?
