1 - 9 of 9 Posts
First thought I had was to smooth down the knurls on the underside of the shift peg. I've had similar wear on my boots and will be sanding the bottom of mine. The knurls are a bit too sharp and a good sanding might alleviate or eliminate your problem.
Good luck
Cool, thx, Blair suggested that as well but think I am just going to deal with it, builds character on my boots...lol
BTW the screw in the peg is 6mm X 20 mm
No prob! But I still recommend sanding it a bit on underside. Your choice tho.
What about a piece of large diameter shrink tubing to cover the shifter? Should only be a buck or two at a local electronics supply house.
You can also take the piece off, stick it an drill chuck (hand or press) and sand it down with a strip of sand paper.
1 - 9 of 9 Posts
