Hi Guys,
I was wondering if anyone had success in fitting gsxr600/750 06/07 rear shock on their Gen 2 SV ?
I found a spreadsheet(which was really helpfull) about what ones fit. Apparentely I only need to remove tool box cover or battery cover and it'll fit ?
I just want to know peoples experiances before I drop some money on it.
edit: I ended up buying zx-6r 06 rear shock. I'll post update on how it goes
Thanks (y)
i see i didint take into account the length .... I managed to find a zx-6r 05/06 rear shock instead ! Thanks for pointing it out
I have a ZX6r Ohlins if you are interested. PM if needed.
Sent from my SM-G998U using Tapatalk
For a length match, you need a ZX14 shock. Has the same 330mm length as the OEM item. I had to trim the flap that goes over the tool kit holder, otherwise a direct bolt on. Changed the spring for my weight and a little bit of clicker clicking, works great.
07 650n
I used a zx10 shock 05 I think it was. I believe this shock was 338mm which lifted the rear maybe a 1/4 inch. Bike handles like it’s on rails for me now with the front forks and sonic springs.
