My right light next to the main headlight went out, so I thought it would be an easy fix by replacing the light bulb. Turns out, I needed to make a new grounding wire for the next light to connect to the wires inside of the headlight. Once everything was connected and I turned my bike on, all the front lights worked. I thought I had fixed the issue, but when I went to rev my bike it blew my headlight low beam fuse and all my front lights went out together. I re-checked my connecting wires and grounding wires and everything appears to be correct. I changed the fuse (10) and started my bike again. The same thing happened when I revved my bike all the lights worked, then they all went out together. Curious to see what the issue is if maybe somewhere else is not grounded. I've never had issues with my lighting before until I needed to change out this lightbulb. Any advice or where to start would be helpful. Thanks.
Side note: I just got a brand new wiring harness a few months back.
