1 - 20 of 28 Posts
Torrential downpour and severe thunderstorms yesterday, but Nate had to get to class anyways. 2 miles short of the 25 mile commute to school, it does it. Oh well it's not the first time. After a few hours of class, I go home and its still firing on one cylinder, rode the whole way home on one cylinder. Question is, does this cause any harm to the bike?
Side note: Would I get better gas mileage too?
Another reason the second gens are better ;D But now someone will say it happens to their second gen :-\
It's better that it is firing both cylinders. It's definitely more fuel efficent with both firing because that fuel in the front cylinder is not ignited and gets blown out with no effiiciency at all; plus, to accelerate and maintain speed, more throttle would be required, thus injecting more fuel. And the fact that it can build up in the cylinder and get past the rings and into the oil... which is no good. I'm not sure right now why else it would be bad.
Josh
I have a second gen...
it doesn't help teh engien to run unburned gas thru it, cylinder walls are washed and some may get past rings and into oil.......
So check the oil then...would it discolor the oil or what? Its fairly fresh oil and I'd rather not change it if there is no effects of gasoline in it.
smell it, if it smells like gas, it's got gas in it
A little gas in the oil won't hurt it a bit. I would just get it fire on both after it rains, and open it up a bit to blow some of the carbon out of there, because chances are after it starts to fire, it will be flooded in that cylinder.
I guess you were stressing "little." If that's the case, then, yes, a little gas in the oil won't hurt. If it becomes excessive (and you can smell it as RandyO pointed out) then you should definitely drain the oil. On the bright side, having fuel in the oil will help release any sludge at the bottom of the case and on bottom end parts like the crank.
That cracks me up that EvilBologna has a second gen when I made that comment... I've never had it happen to mine and I ride in the rain frequently: often getting hosed.
Quit hitting the puddles on purpose to watch the big splash and you won't have that problem anymore ..... :p
It was pretty nasty out yesterday. Residual hurricane stuff that made it all the way up here.
Are you going to BCC?
I feel like such a noob asking, but why does the rain cause the cylinder to stop firing? Is water getting in through the airbox? How would it do that? Why don't both cylinders stop? Do all bikes have this problem?
Water pools up around the spark plug, and shorts it out.
I used a little dielectric grease and it seems to help. I just try to avoid heavy rain.
Josh
It hasn't happened to my 1st gen yet, and I've been hosed more than a couple times! Take that evil Josh.
-josh
o when i was in NH rain week (bikeweek) cough it rained and i never had a problem
when i went to North Carolina i rode in the most rain i ever rode in standing water preaty dam high.
sv kept chuggin. i loved my sv.
All I know....is the SV really sucks as a 325 single.
Check out the Holeshot Fenda Extenda and dilectric grease. If you're having cylinder firing problems after that...it's because your underwater.
the boot usually only leaks if it's shape is distorted from not getting is plugged on straight.
get a new plug boot, keep the drain hole clean and dilectric grease & fenda extenda are not necessary
Like Randy-O said, keep that drain clean. I had issues with my bike after a year. Turns out the drain was clogged. Once I started cleaning that regularly I never had problems, even riding through peg+ level water....(I haven't needed to use a fender extender or grease or anything but YMMV). I've just added a few pipe cleaners in with my tool kit just in case.
Discussion Starter · #20 ·
Yup, and my choice of vehicles to get there is the SV, my friends F4i thats sitting in my garage, and my minivan that is missing its serpantine belt, power steering pulley and a few other things.
Surprisingly there are more cruisers that have been parking at BCC, I was expecting a huge squidfest. The cruisers aren't even being piloted by older men, they are mostly students my age too. Weird, but I like it, they aren't jackasses.
The two days it rained my SV was the only bike there 8)
1 - 20 of 28 Posts
