Did you test it according to the shop manual to say it seems to be working fine?I have tested the switch itself and that seems to be working fine....
Is this bike new to you? Did anything happen just before the problem started?... my sv1000 runs great but it won't stop on the switch and have to use the key to stop.
So, OP could start the bike and THEN unplug it and see if it shuts off.I think the connector he needs to unplug also contains the start button contacts. Would be easy enough to locate on the connector side and short across them to start, I guess. I’m thinking it’ll try to start.
He could also just live with using the key, which I do anyway. But I also don’t like the thought of something being wrong and unexplained. What might happen next?
We do have the occasional welded starter relay, which would keep the starter and engine turning, but not running, per se, if the kill switch was turned off. If I remember correctly.Is this bike new to you? Did anything happen just before the problem started?
We see lots of "Help! My bike won't start." posts, but not too many "Help! My bike won't stop." lol.
Would be something to try. My money is on it staying running.So, OP could start the bike and THEN unplug it and see if it shuts off.
As GC and Troy said, if the bike stayed running even with the switch unplugged then for sure the problem is not the switch.... I unplugged the right bar control and nothing happens ,
