I put SFV wheel on bike with 09 SV ABS rear caliper bracket. I have also used the SFV rear bracket on another bike. Done, it's just like putting your normal SV wheel on... What more do you need?If it bolts up then mind sharing what you did?
I gave correct information...Sfv650 wheels are not direct bolt on with a just a rear caliper bracket. You need to figure out another speed sensor, rear caliper/pad, front sprocket and chain. I will post the diy once im done so people can actually refer to correct information.
Im not arguing with you over the chain issue, i ran everything 520 because i had to replace anyway chain and sprocket anyway, dont see a reason to run missmatched. The rear wheel does bolt on with an SFV bracket, but now the caliper or pads dont fit, so not exactly a bolt on fit if you ask me. And the reason why i posted in the first place is because the OP asked initially if both wheels fit as he was interested in the wheels as more of a cosmetic apeal. On a site like this one would hope that everyone here tries to help each other out and provide as much info as possible so the community can thrive, thus my continuation of this thread.I put SFV wheel on bike with 09 SV ABS rear caliper bracket. I have also used the SFV rear bracket on another bike. Done, it's just like putting your normal SV wheel on... What more do you need?
You are over complicating it by adding in the sprocket/chain bullsh1t. 520 does not matter since the SV 525 chain will work on 520 sprocket. Many have 520 chains anyway. Front wheel is different story but I don't care about that. I only cared about rear wheel for width over the stock wheel. Anyone that does front GSXR swap has to deal with speedo sensor as well.
Simple question, does it bolt on? Yes, if you have SFV or SV ABS rear caliper bracket.
2g only... 1g has its own thing for brakes etc...Nice pickup SVD. Zombie threads can be useful. I did not realize Gladys/3Gs had 5" rear wheels. A perfect easy modification (excuse me, mod in lazy parlance) for 1G/2G owners.
why though? sfv/3g wheels are heavierJust when I think I'm actually getting to the end of my upgrade plans for my 12yo SV.. ;-)
...miles to go before I sleep ;-)
thats a fine reason. there's a large enough population in here that goes "performance only" (obviously im one of them) and shudders at the thought of adding unsprung rotating massTo be different. to be unique,.. to go slower... ;-)
I just like building unique cool fun stuff...![]()
You young whipper snappers! Gotta learn to slow down and enjoy the music.(obviously im one of them)
