1 - 13 of 13 Posts
Thought I'd start a thread for you SV lovers out there. Can be anything about the SV or anything that is a pic of your day.. here it goes..
Ebay delivered my new to me Ricor shock. Changed the spring for my weight - painful without proper tools 😝. But I got it in there 😁😁
Automotive tire Coil spring Gas Shock absorber Auto part
Audio equipment Coil spring Red Automotive tire Auto part
Sorry I meant to clean the area while I was there as I just rode it through heavy rain a few days ago.
Camera accessory Automotive tire Flash photography Cameras & optics Camera lens
Automotive tire Motor vehicle Rim Bumper Automotive exterior
Nice to have the other measurements, though. 475lbs is pretty light, isn’t it? I weigh closer to 250lbs, so the spring rate would have to be a bit higher!
At least for my Ricor shock this is the chart. Not really familiar with other brands.
I'll give you a shock related picture. I was at Blackhawk Farms yesterday and the suspension guy was looking over my Penske 8983 shock. He noticed the collar had no set screw nor a spot that accepts a set screw--so it has been backing itself out slowly over the course of the year and adding sag. This was the misalignment after 2 sessions. So, it's not major, but next time I pull the shock for servicing I'll have them install a new collar.
Tire Motor vehicle Wheel Automotive tire Hood
It was my first weekend using the Pirelli SC3 TD "Track Day" tire. I'd been using Bridgestone S22's up to this point. I was nowhere near using the limit of grip of the S22's, so the Pirelli is just going to offer more of what I already wasn't using all of. What was a noticeable change was the profile of the tire itself. It took me about a day to get used to the profile difference and how it affected tip in and stability. Felt very different than what I was used to.
Tire Wheel Bicycle wheel Land vehicle Bicycle frame
Took a ride out to the ocean for labor day. This was my first longer trip on this bike (still only ~ 50miles each way). I wish I were a better photographer, I don't think I captured the feeling very well. This spot is cool because planes landing at the airport usually fly right over on their landing approach path, so you get to see them a lot closer than you usually do.
Wheel Tire Sky Land vehicle Vehicle
Sky Water Tire Wheel Automotive tire
1 - 13 of 13 Posts
