1 - 7 of 7 Posts
The subframe that connects my headlight to the frame. Is that just bolts or welded? I ask because I have movement in mine and I cant tell if it's a loose bolt or broken weld. Still havent gotten brave enough to start pulling of parts.
bolted and "hooked" to the main frame. pinned to headlight. bolted and hooked to fairing.
it's usually called the "main fairing stay" or "front fairing stay"
It's bolted to the front of the frame, at the steering head. There are 2 bolts holding the fairing stay in place there. Mine rattle loose once and the whole fairing assembly bounced when I was going down the road. You should be able to tighten up those 2 bolts and be good to go.
Discussion Starter #7
Thank you for your help, I believe the previous owner thought zipties are acceptable. Glad I have a much higher standard than that for myself and/or if I ever sell it
1 - 7 of 7 Posts
