1 - 7 of 7 Posts
I need to get the paint off my sharkskinz fiberglass tail... Seems like I read that using a chemical stripper is bad because it stays in the fiberglass and screws up the new paint when you repaint it.. is that true? Am I stuck using mah elbow grease to sand that biatch down? Remind me what grit to use. Thanks. :-*
I was wondering the same thing for the stock body work. Screw elbow grease, I'm thinking 15 minutes in a bead blaster set on low would do the trick.
stranger said:
why can't you just sand, prime over it and repaint?
sigh... thats prolly what ima have to do. sucks though. :(
stranger said:
did i just help again?  :eek: damn, i should leave
no you didn't, I knew that was probably going to be what I was relegated to.. I was hoping someone had an ALTERNATIVE solution. :p
don't get a big head, those two times you helped were freak accidents.
phew. that means i can stay, right? what if i promise not to help anymore?
1 - 7 of 7 Posts
