My bike was knocked down and the handlebar was bent, which I've since replaced with a stock one. However. the steering is still not straight. When the bike is going straight, the left grip is about 10 degrees below the level of the right grip.
I doubt the forks are bent but something definetely moved out of its place. I have read some messages advising to loosen the stem nuts (?) and/or triple clamp nuts (?) and either hitting a wall (! ?? !) or trying to straighten the steering while holding the front wheel between legs.
What is the correct procedure for this? I would appreciate it if somebody could explain step by step.
Thanks a lot.
Oktay
Thanks a lot.
Oktay
