I don't even know what happened, I took a ride this morning, everything eas fine, stop to get gas, everything was fine, however, that was the end of my fine day. I get on it, try to start it, and the starter button is stuck, won't move in either direction. The pump works good, but I can't press the button...finnaly I had to push it to start and rode it home, but the button is still stuck. What to do? Warranty should cover this, right? I am not sure I want to take it apart myself, but if it is something simple, then I probably could. Anyone has a similar/same problem. BTW, the bike is 05 gsxr 750 with 3.5K miles. evertything else seems to be fine. All help is apprechiated. thank you.
