1 - 3 of 3 Posts
Trying to build an 00 SV from a non runner with blown engine. I fired up the electronics. The speedo sits and direct south beyond the zero tab and when you turn on the ignition key the needle goes up to the tab and stops. Somehow it got on the other side of the stop tab. Is it trash? Can I take it apart and put the needle where it should be?
Thanks
Discussion Starter · #2 ·
Just a follow up for anyone reading this post. I was able to take speedo face off and manually move dial back around. Speedo now works. I think I had a votalge spike due to putting jumper cables from my car on the bike when trying to start with a bad battery.......
Glad you got it working. Thanks for the update!
1 - 3 of 3 Posts
