1 - 2 of 2 Posts
2002 SV650S
Hi guys,
I got my license a couple months back and bought a 2002 SV650S, which is tuned back to 25kW so it is compatible with an A2 license. I have driven it for approx. 2000km and as it approaches the 48000km I wanted to check the spark plugs. The plugs look clean and there is no build up of any sort on the tips, however they have turned a bit black so I am unsure about the condition. The threads feel a bit greasy, but aren't wet with oil.
For now, I only removed the spark plug of the rear cylinder as the front one is a bit harder to remove.
It is a NGK CR9E and the gap is 0.7mm. Could anyone tell me more about the condition?
Thanks!
Wood Household hardware Fastener Nickel Metal
Wood Auto part Metal Font Fashion accessory
AFAIK the only reason to run a CR9E is if you're in high RPM situations a lot of the time (like a track bike) as it is a colder plug.
For standard even spirited street riding I'd swap back to the OEM plug of CR8E, especially given the cost of plugs. :D
Now with the power limited tuning maybe you and the PO are both in high RPMs all the time so maybe that's intended? Or maybe it's a function of the limited tuning itself, not sure!
1 - 2 of 2 Posts
