1 - 2 of 2 Posts
im copying this from my thread on my site. Ill keep the most updated one here
Racebook - http://www.svracer.org/files/Racebook.pdf
Use this to keep track of changes made to the bike through out the day
Valve Chart - http://www.svracer.org/files/SV Valve Clearance.pdf
When checking your valves, this makes it handy to remember which measurement came from where
Valve Calc - http://www.svracer.org/files/Valve Calculator.xls
Input the values from the Valve chart, and will calculate the recommended new shims to use. Will also tell the clearance you should get from the new shims you ultimately put in.
as i come up with more, ill post them up
1 - 2 of 2 Posts
