Hello guys,
I've read all the threads regarding the 'no spark' subject.
So the story is that my I rode the SV with a bad R/R (overcharging) and it died on me.
I checked the connections, everything is in order, except for the orange/red wire at the ignitor.
I jumped it with the 100 Ohm resistor but I can't read (5, 7) volts there; it's only about 0.8 volts - This happens only with a good working ECU (with the original ECU, the reading's 0 - maybe this could be a quick test of the ECU?)
So in the ECU connector I have:
What I might have missed (from other threads, not yet checked):
I checked for a spark visually and have no luck :|
On the bright side, I've learned so much these days.
Do you guys have some ideas as to what further I should check?
- 190 Ohms from the pulse generator;
- 12V on ECU power wires
- 100 Ohms on the anti-theft system (jumped it)
- 0.8V on the anti-theft wires (it doesn't matter where I ground, still the same reading)
- "Before throwing in the towel, you might check the ground between the battery and the Black/White wire at the ignitor. Probe B/W as close to the ignitor as possible to include the full wire. Resistance should be well under one ohm. Voltage drop on the same path (with power on) is a more accurate measurement and should read close to zero volts, maybe a few tens of millivolts."
- Signal generator if it's grounded;
- "Follow the negative wire from your battery, it connects to your motor near the bottom on the 2nd cylinder, remove the lug, clean it up nice and replace"
