I would give it more than 7 days, and then carefully sand it dull with 1000 wet before clearing it - with only very light sanding on edges or sharp bodylines for fear of going through the base.Not meaning to bump this, but I had a question. I recently did this method of painting my bike, using duplicolor engine enamel white. Now, the difference is that I bought some spraymax 2k urethane clear coat... and want to use that over the base. Is this possible? Or is it going to cause the paint to chip and crack. I am giving the duplicolor 7 days dry time before clearing it like the instructions say, but I want to make sure.
Wait until you can't smell solvents to clear it or you may have problems, seeing as it's not the same type of finish. Hopefully the engine enamel doesn't require high heat to cure - some high heat paints do.
Once the finish is cured it shouldn't be any problem clearing over it, but you don't want to clear over a shiny (cured and unsanded) finish or it will peel.
This technique will only work on solid colors, not metallics, and the base paint needs to thick enough to take the (light) sanding.
Jay
