Did it break off flush with the top of the treads in the frame?
i had to take off my radiator because i went down and wanted to check it out a bit more thoroughly.. i take it off.. everything seems fine.. i go to put it back and as im tightning the top bolt on the right it snaps off... now i have no clue what to do.. should i try and drill it out? or take it to a pro?... its the bolt that holds the radiator to the frame.. help please!
If you do decide to drill it out and use an easy out make sure you use a punch to set a small indent (pilot) into the center of the bolt. Then use small drill bits going up to the size your easy out recommends. Take your time and drill straight.If you can move the radiator out of the way an enough of it is poking out of the frame, you might be able to grab it with vice grips. Otherwise, you'll need to go buy an easy out and drill bit for the easy out if you don't already have one. Google easy out bolt remover or something along those lines.
On the subject of easyouts, Use the largesy one you can possibly use. I was once worried about damaging the surrounding threads and used once that was too small (so it would only require a small hole) and the ****ed thing broke off in the hole. They are made of metal that is only slightly less hard then most drill bits so removing one that is broken off in the hole is a huge PITA.If you do decide to drill it out and use an easy out make sure you use a punch to set a small indent (pilot) into the center of the bolt. Then use small drill bits going up to the size your easy out recommends. Take your time and drill straight.
+1 DON'T BREAK ANY TOOL OFF IN THE HOLE!!!On the subject of easyouts, Use the largest one you can possibly use. I was once worried about damaging the surrounding threads and used once that was too small (so it would only require a small hole) and the ****ed thing broke off in the hole. They are made of metal that is only slightly less hard then most drill bits so removing one that is broken off in the hole is a huge PITA.
Yeah a little PL 400 fixes all kinds of stuff. Heck might as well use some JB Weld.A generous blob of construction adhesive would hold your radiator on. :tard:
