So i just installed a used hindle slip-on on the sv650 and she sounds f***ing amazing. My one concern is although i tightened the clamp around the midpipe/stock sv exhaust area as tight as possible, there is still air leaking through. Is this something worth worrying about? If so is there anything I can do to stop it from happening?
When ever I installed my slip on I had the same problem. Right at the joint there were a few small leaks around the circumference of the clamp. I used some of the RTV copper exhaust sealant around the inside of the joint. And it worked great. You can get it any most autoparts stores. This is what I used http://www.autobarn.net/per81878.html
