1 - 9 of 9 Posts
So twice in the last two weeks this has happened.
Im cruising along happy as a clam when I go to shift and then **** pedal just falls off. Its still hanging there by the part that goes to the transmission but the part that attaches to the rearset(?) vibrates loose and falls right off.
I cant seem to tighten it enough with the tools in the bag.
Im sure someone else has had this problem. Please give me a fix.
Thanks!
Sounds like the circlip is missing.
So when I screw it as far in as I can it isnt even sticking out the other side. There is a circlip on the outside holding the pedal to the part that screws.
I dont know my part names very well......
I actully had this happen to me on Sunday. I was at a red light and went to go pop into gear and there was nothing there.
I had pointed the culpret to me swapping my shifter out for a busa one because I busted mine in a low speed drop, and I never re-greased the shaft :)
Have many others done this or is it a rarity to have the entire thing pop off?
Awesome. Ill pick up some blue Loctite next time Im out. Thanks for the info all!
--Ben
1 - 9 of 9 Posts
