1 - 10 of 10 Posts
I installed Vortex rearsets and using a GP pattern the shift rod is no where near long enough. It's probably an inch or 1.5" to make up the distance. Where do you buy custom length rods since I don't know where I'd buy a left handed thread die.
Also, looking down at the shift rod it's tilted to connect to the shift arm and not straight. I assume I can use a spacer but anybody else have this problem?
My vortex rearsets came with 2 different rods. One for regular shift, one for GP shift. Did you get both?
So is mine (regular shift). That's just the way it is I guess. It doesn't seem to affect anything.
Contact Vortex?
I know that probolt-USA sells shift rods in multiple lengths and in colors as a bonus. Just measure and figure out how long you need. I think it's in mm, but not a hard conversion.
As a side note, harbor freight sells a mini metric tape measure (10 ft) that is perfect for setting sag and a number of other bike related tasks like measuring bolt and rod lengths.
I don't know where you're at, but any reasonable sized town will have an engineering supply store that will sell you a left hand die nut, probably straight out of stock :)
I bought these used but it came with one really long shift rod that I figured would fit.
Googling left handed die's brought up some cheap options and since I need 2 of these I might just make my own. Are these always made out of Al or SS? Can you cut threads into SS without a lathe/drill motor?
You sure can, just Google the technique and don't ignore some sort of oil for a cutting lubricant :) Probably the hardest part is remembering to cut the right way :D
1 - 10 of 10 Posts
