1 - 12 of 12 Posts
My SFV still has some issues I need to fix, i got it running post accident but found out 1 fork, handle bar and maybe the rim might be bent. Rideable but scary to ride. Which is not normally an issue since I have a spare bike, my ninja 300 which is now having some issues. Hoping someone could assist me.
https://youtu.be/n0b-8LUPogk
Main symptoms: Bike is running on 50% power with the occasion 100%. When you power it on, it turns on fine, after about a minute, RPMS drops significantly. Causes the bike to go below 1k rps and occasionally will jump 1.5k-2k (normal) rpms. Leave it long enough and it will turn off. When you do full throttle in N, the bike SLOWLY climbs its RPM scale.
Modification done to it: Exhaust only and K&N Air Filter. Nothing else. Slip on.
Issue started about 2-3 weeks ago. Bike was running great, I would notice it would idle kind of weird after the exhaust swap, idle would very slight drop but nothing that caused me to have any concerns. It wasn't until I performed a tune up on that the issue got really bad. I did an OIL change on it, I used Rotella oil as I like to do my oil changes quite frequently. I added iridium spark plugs on it. Everything worked great for about 50 miles and that's when the bike would run on 50% power. See video. I thought, OK maybe it did not like the iridium sparks plugs. I added stock spark plugs, worked just fine for about 200 miles and now I have the EXACT same issue.
I am about to take the sparks plug off again. What should I be looking for? Could my COILS be bad? The bike barely has 6k miles on it.
Discussion Starter #3
I am sharing 2 pictures *links below*.
I see what looks like GUNK on the coils, they look like rust and gunk in one. Is that normal? That wasn't there 2 weeks ago when I worked on it. The spark plug has about 300 miles on it and they look like they already have a few thousand miles on it.
https://drive.google.com/open?id=1J734BA82WqUhreNL_mQfYwUhaLYJ2kxy
https://drive.google.com/open?id=1JAJ-OXFW6C-yLQbFibZgTdFoMfjNWeGN
Oil or water in the spark plug wells could be shorting out your ignition.
Like maybe I put too much oil or a ruptured water gasket? Any recommendations?
When it's running poorly spray each exhaust pipe with water to see if one is cold. If one is, then thats the one you want to focus on.
Test at the header pipes as they exit the engine.
I agree. It's a straight twin, so you have two header pipes.
You could try the old hand method and see which one is
cold, or an infrared thermometer would be better.
1 - 12 of 12 Posts
