1 - 20 of 20 Posts
Was at CMP last weekend. Coming off Pirellis going to Dunlop, 211 US front/ 209 UK rear. Had huge issues with setup for the Dunlops. Was hoping someone here was on the same tires and could tell me their settings for suspension and geometry. What I ended up with after a day was 4.5 turns of preload on the Penske with a 450lb spring (i am 150 without gear), shortened it all the way although I honestly dont know the total length. Forks pulled up 10mm, 4 turns on racetech emulators, 15 weight oil, .85 springs. I have a 500lb spring that I was planning on putting on for the next time out. Preload in the shock made the most improvement so I am assuming the stiffer tires are sending too much energy into the suspension with the softer settings for the Pirellis. My biggest problem was the front end sawing under acceleration. The rear felt the same until we lowered and added more preload, still a little there but improved.
The main reason for the switch is that dunlop is the only company that has a 160 race dot that also pays contingency. But I guess contingency is no good if I can't ride the **** thing. I know they after very different tires but the effect on the bike is much more significant than I thought it would be. First couple sessions out I thought I was going to crash in every corner. Tires seemed to be gripping but the chassis was all over the place. We started to go in the right direction by the end of the day but I had lost all confidence by then. The biggest problem I was having was the bike would sway whenever I got on the gas without being upright. It was to the point where I only rode 50 miles the while day and usually when coaching I'll ride 40 minuets every hour.
Pretty good Dunlop following here in the CRA, split about 50/50 Dunlop / Bridgestone. Last year there were some Michelins because they paid well but I'm not aware of anyone still using those this year.
Although the top 8 or so experts are all on Bridgestone.
Discussion Starter · #16 ·
Thanks but i have that paper also. I tried different pressures all day and pressure alone would not cause what I was experiencing. And the tires actually wore great.
Went over the bike today and I think I found my problem. The shock was at about 330mm, guess thats what I get for not researching and taking measurements beforehand. Set to 343 now.
If you're still running 21psi in the rear, I bet you still have problems.
1 - 20 of 20 Posts
