So, I got a FI error on my bike - stuck a paperclip in it to get to dealer mode, and found out it was c28. Secondary throttle valve actuator. When I read the error I did some troubleshooting with the actuator, and noticed it isn't moving back like it is supposed to - instead, it just swings to wide open, and in doing so, it turns on the fast idle and it starts idling at 3500 RPM. Normally, the STV has two motions when you turn the bike on - however, mine is only going through one of the two movements.
I have checked voltage, and I have checked the STV position sensor's resistance. I set it to as close to within range of TLRMan's recommended settings as I could. Still, no luck.
So, being the enterprising person that I am, I started fidgeting with the butterflies and the STV actuator "rod" (the rod that goes through the actuator w/ the 10mm nut on the end, and the mechanism for pushing the fast idle cam). I found out if I manually set it to wide open with the bike off, then turn it on, the STV's move twice, like they are supposed to, and the FI code goes away. Movement of the STV position sensor then changes the position of the STV's, too. Seat of my pants testing confirms, that the STV's do work when I do that.
However, it doesn't always kick off the code, and the STVA doesn't always do it's second movement back like it is supposed to when I manually set it to the resting position it's supposed to revert to. A third of the time it sticks in WOT, a third of the time it sticks fully closed and my bike becomes asthmatic, and the other third of the time, it works perfectly.
So, does anyone have any ideas as to what is going on? Does the bike need to read the correct resistance at startup from the STV position sensor to move them closed and open again, and that is why it's giving me issues with it being stuck on fast idle until I manually move the plates? Is my STVA dying?
Does anyone know of a solution to removing the secondary throttle valves, rods, and servo, but keep the fast idle mechanism? This is an '03 SV1000, so I'm game to buy one of the later year bigger throttle bodies and fudge around with it to try out any ideas. Thanks!
