I also have an 03S and last Nov I put in the shock from a 2012 ZX6R. From memory the length was about 6mm longer than stock, and u need to use the bottom bolt from the ZX6R as the SV one is a little short. As u can see from the pics, u have to cut a section out from the battery box to make it fit. BUT it's nowhere near as bad as it looks, as the reservoir is only 10-15 mm too tall. With a little bit of padding or the OEM battery tray, the YTX12 battery still fits (possibly due to the higher subframe in the 03). Or you could change to YTX9 (shorter and I've run that in another SV with no problems at all)Were you able to install this shock and give it a go? I'm looking for an OEM rear shock for my '03 650s. Thanks!
