You're way better off using Google to search SVrider than using the resident search tools. The reason for this is if you search something like "damper rods drilling" you will get any post with damper or rods or drilling
better to use google and search "damper rods drilling site:svrider.com" Using the site: function in Google will allow you to search any site without searching the whole web.
In the "damper rods drilling site:svrider.com" example above you will get only posts with damper rods and drilling, not any of the three terms. It's much more accurate.
You can also use Boolean commands like "damper rods drilling site:svrider.com -preload" if for some reason you wanted to remove all posts where preload is included in the discussion.
I am oftern frustrated by the search tool when I am trying to find technical information on the site and it comes back buried a mega list of posts that really are not relevent. This method has worked way better for me. Hope it helps someone else.
