I saw this Ducati Monster with what appeared to be a screw in oil presure guage where you fill the case with oil. Is there such a thing? Where do you get one?
Yes, you can
There are a couple of oil pressure ports that are plugged on the SV engine. I don't remember where they are exactly. Knowing the thread size you could go to an industrial gauge supplier and buy a direct mount gauge. If you were brave and industrious you could plumb up a line and mount the gauge up top.
I think it would be of limited use, given the SV's proven reliability and long lifeline.
Pressure gauge or temp guage? Unless the whole crankcase were filled woth pressurized oil (!) I can't see how it would work. Screw in oil temp guages were common back when SOHC CB750s roamed the earth.
At risk of sounding like a total chump here. I just really thought it looked cool. Plus I have a total analog guage fetish.
I'm using my 03 for performance mods only and my 02 is just a communter. So I figure adding little look only things to it makes since.
Now to find those ports.
If you go with a conventional gauge the sender usually just screws in where the oil pressure switch goes (and replaces it, unless you add a 'T'). If you do buy a gauge, get an electric one, and a good one (AutoMeter etc) IME, (is that a legit abbreviation? In My Experience) the cheap guages don't survive long on a bike.
Also, If we're talking about a 2nd gen bike you may have additional options since you have an oil cooler (plumbing for this may occupy the ports andyauger referred to).
Shop manual
The shop manual has the port locations. I, too, like analog gauges. I never liked digital gauges. It's easy to detect the position of a needle, not so straightforward reading digits peripherally.
