Probably shorted something and blew a fuse. I've done it before its a quick, easy and cheap fix.
I'm normally pretty careful to not turn it too far but maybe I did in the haste of trying to get in from the rain. Can I jump it from my car, I don't have anything else.If the lights dont even come on then I'd say its a dead battery to start.
Do you use the steering lock? Is it possible you turned the key too far and left the marker lights on?
Bingo was his name o.If the lights dont even come on then I'd say its a dead battery to start.
bike charging systems don't work like automotive charging systems, they barely put out a trickle above what is required to run the bike, you'd be lucky to recharge the battery enuf to start a bike after riding a full tank of gas, let alone charge the battery to fullcouldn't he bump it? and ride for a minute to charge the battery back up?
B.S. That is impossible to do.Yes but DON'T start the car it will blow the battery up. If you can get your hands on a trickle charger thats your best bet.
That's the problem, too many urban legends! Here is why it is BS- you won't fry your regulator because the voltage has already been regulated by the car's regulator to 14.5 volts. The bike will only draw as many amps as it needs to get started, or to charge the battery. The car regulator is capable of ramping back just fine on its' own. If what you were saying were true, then the amps in the system that drive your headlights would blow out your significantly smaller turn signal bulbs. But that doesn't happen does it? No- Why? because the bulb only draws what it needs.You can jump a bike with a car. If the car is running you will fry your regulator/rectifier possibly due to the extra amps put out by the cars alternator. You will not blow your battery up though.
It's too bad you aren't as intelligent as you think you are. The reason you never had a problem on your race bike is because you had no charging system which means it was an open system essentially. You do what you want though.That's the problem, too many urban legends! Here is why it is BS- you won't fry your regulator because the voltage has already been regulated by the car's regulator to 14.5 volts. The bike will only draw as many amps as it needs to get started, or to charge the battery. The car regulator is capable of ramping back just fine on its' own. If what you were saying were true, then the amps in the system that drive your headlights would blow out your significantly smaller turn signal bulbs. But that doesn't happen does it? No- Why? because the bulb only draws what it needs.
My race bike years ago had no charging system, because I removed it all to save weight and drag on the engine. Between races I had a pigtail off my tow vehicle that I plugged into the bike to charge battery, and I'd just let the truck idle for a half hour or so. Saved me having to cart around a generator like so many other racers did at the time. The bike would run for hours on a single charge with no lights to drive.
you sure about that..It's too bad you aren't as intelligent as you think you are. The reason you never had a problem on your race bike is because you had no charging system which means it was an open system essentially. You do what you want though.
EDIT: Post above me saved me a lot of explaining.
Do you care to elaborate as to how it doesn't?you sure about that..
whether or not the bike has a charging system has nothing to do with hooking up a dead bike battery to a car
