I've been securing some more stuff on the SV and I still need to wire oil lines and silicone the gallery plugs. How many gallery plugs are there and which bolts/plugs are they? Looks like there is one allen head plug on the bottom, and looking through my manual it says a bolt on the shifter side between the two oil line bolts is the "main oil gallery." Is there anything else, and should I silicone stuff like the crank hole and timing window?
I think I read the oil line bolts can just be drilled through on the bike. Just wanted to be sure before I ruin a banjo bolt.
This is all being done per WERA tech on a pointy sv, if it matters.
