1 - 7 of 7 Posts
I've installed my Yosh TRS system and they (Yoshimura) recommned safety wiring the exhaust springs.
I'm pretty compotent with a pair of safety wire pliers but this isn't obvious to me.
If I wire it so the spring can't expand then I'm pretty much defeating the purpose of the spring, correct?
Any help would be appreciated.
I've raced a couple seasons and have never heard of safety wiring exhaust springs.
Exhaust fasteners had to be wired but not springs... which is why most aftermarket exhausts use springs ;)
You run the wire around one spring mount and twist a section long enough to pass through the spring then attach to the opposite spring mount, leave a little slack and your done. If the spring falls off or breaks from fatigue, the parts will still be attached, not laying the the track surface. ;)
Thanks Duc.
Exactly what I needed.
I got schooled :-[
(ya learn somethign new every day!).
PS. Who requires it?
Yoshimura recommends it.
OMRRA and PSSR give it 2 thumbs up but don't require it at this point.
J
1 - 7 of 7 Posts
