1 - 8 of 8 Posts
Hey guys n gals. I converted my 2003 to Naked and I have a few questions for the all knowing.
1) I am using a Vapor and would like to get rid of the stock speed sensor and wire. Is there a spacer dust cap combo that would take care of this? I don't really want to just cut the wire off as it unit is in good shape.
2) I picked up some Dominator headlights and would like to plug them into the stock harness. Is there anywhere that sells plugs so I don't have to hack up the stock harness or cut off the plug from my S headlights?
3) Do the N models have this casting on the front of the frame? I want to mount the Dominators as tight to the frame as I can but the S fairing mount is sticking out. I am considering cutting it off. Thoughts?
very big dumb
aztec8 makes brackets for headlights.
i think you're supposed to mount them to the forks not the frame?
wouldn't cut that off in case you decide to go back to fairing at some point
SV Hadder
you can use electrical spades to connect your dominators directly to the stock plug.
just find the right size (i forget which side is male/female.)
Yes it does. If you were closer to me I'd trade radiators with you. The N radiator has a cap instead of a peice of rubber tubing.
My bike was an N and I converted it to S.
That would be nice. The tube sticking up is fugly! My rad is a little banged up from the PO.
There is a little dimple in my plastics where the radiator cap protrudes. I had to cover it with a piece of foam so it still rubs but isn't as noticeable.
If you haven't already, get some motosliders. The '03 rads stick out 1/2" more on each side than the '04+ rads.
1 - 8 of 8 Posts
