1 - 4 of 4 Posts
HI, I was just about to install goodridge front s s/s brake lines. If anyone has installed these mabee you could tell me if you bypass the factory junction. It seems that the lines would be too long if they were ran from the junction. By this I mean from the lever there is one line which goes to a junction block, from there two lines come out (one to each caliper). I am assuming that the new lines both go directly from the lever to the calipers. thanks
uh.. yes... and you no longer need the junction...
one line for each caliper directly from the lever.
You'll love it!
Just make sure you use cable ties to hold the new lines or they will catch on something.
also make sure that the bolts they sent you are the right ones. they often come with the wrong pitch bolts. IIRC the caliper bolts are fine pitch and the MC bolt is coarse....or vice versa. Just visually compare the old bolt with the new ones. I ended up using my original caliper bolts casue the new ones were wrong. the MC bolt should be right though.
1 - 4 of 4 Posts
