Hi,
I have a friend who is going to import some H4 HID projectors for his FJC. I was wondering if the projectors will fit in my SV650S housing since they're H4s too. Below is the dimension of the H4 HID projectors, basically I'm asking is the depth of housing at least 4" (10cm) deep so that I can open up the housing and insert these projectors.
On the FJC (H4 headlights) these are direct bolt-on, so I'm assuming the SV650S will be the same. All you have to do is take apart the housing and insert these in from the front. If someone knows the dimensions of the housing then I'll give this a try. Hope so!
Thanks,
TJ
Thanks,
TJ
