Rubber piece on bar ends
778 Views 7 Replies 6 Participants Last post by  BossMan
During a move process I lost the rubber piece and bolt that go on the inside of the stock bar ends. Does anyone know where I can buy just the rubber pieces? Im sure i can find a bolt at a hardware store. And it sounds like the stock bar ends work just as good as any aftermarket ones that are somewhat pricey.
Btw, im looking into cheapish bar end mirrors that wont even need the bar ends, but for now I just wanna use the stock bar ends because i have the third eye mirrors installed to them.
Thanks in advance.
1 - 8 of 8 Posts
$3 isn't bad. I'm in the process of making new barend/extenders, and was going to go with 2(or more) O-rings, similar to my throttlemeisters.
Alright, thanks guys. Ill run to the hardware store this weekend and try out the well nut or rubber hose.
Hose will not have the wall thickness necessary. I would look in the plumbing isle for rubber washers and stack several of them.
I bought some very cheap bar ends, and took the bungs off those, cost about $3 for a pair.
Wow, those were cheap!
1 - 8 of 8 Posts
