Hello can somebody give me some advice?I adjusted the valve clearences on my SV 1000 and now when i start it revs up to 6000rpm and stays there,it's not the idle screw please help!
Check your throttle cable routing.
Also, with the engine off, open the throttle all the way and let go of it. Listen to make sure it's snapping closed cleanly.
Yes I checked that as well everything on the throttle side is ok,I checked everything I know about and all looks good but it still revs like crazy :(
Found the problem! :lmao: on the front cylinder was the fan cable wedged in the throttle links,I diden't noticed on the first look,thanks Jay V for making me double check :D
