1 - 3 of 3 Posts
Any time that an incandescent light stops working, the first step to troubleshooting is always to replace the bulb. If this doesn't work, then suspect something else is wrong. Spend $0.50 and get a new bulb.
Easy check. Hit the left side switch, watch the blinker speed. Now hit the right side switch. If the working rear right light blinks faster than the left side did the bulb is out. To double check remove the bulb from the left side and put it in the right. Most likely the bulb is out.
1 - 3 of 3 Posts
