1 - 10 of 10 Posts
Dont ask for pics I will get them this weekend.
As for the install. The fairing came in a large box and was in good shape when i recieved it. The mounting holes are all marked with the "Approximate" locations. I first started by mouting the lower fairing at the exhaust mount location. I then began to cut out the headlight holes in the upper fairing. After I finished that I layed out my holes for connecting the upper and lower fairing. You can lay it out anyway you want depending on how much of a pain you want it to be to get to them. After that I drilled the holes for the upper mounting bracket. Then I installed the upper fairing and connected it to the lower fairing. I must say at this point the adjusting portion of this fairing can take a while but its not that bad.
Problem 1
The hole that was marked for the exhuast mount was about 3/4" to far back on the fairing pushing the fairing foward so the headlights didnt fit into the holes. Easy fix, I just drilled a new hole and and remounted looks great now.
Problem 2
If the upper and lower fairing arent lined up just right the lines dont look even and the panels "bubble."
Problem 3
The rear brake pedal hits the fairing. Easy fix just had to trim it.
I also had to make some custom brackets for the windscreen.
All and all it took me 8 hrs to get it to look right/fit right. People all say they have to cut holes in the fairing thats BULL! It doesnt touch and heat shield will be sure no paint damage will happen. I think that the fairing fits pretty well for something that didnt come from the factory. I really like the way it looks and can not wait to get her painted. For those of you looking for a full front for Gen 1 or 2 go with Ken. His stuff is good quality and it fits pretty well. For half the price of two wheel junkie I think its well worth it.
i have this fairing and i like it, when i mounted my fairings tho the pipe was leaning against the fairing and actually turned it brown (this was way before i painted it) so i had to cut it and also do heat shield all around the rest.
a lil advice, when attaching your lowers to ur uppers, do no less than 4 screws.. one on each end, 2 in the middle
i think he had 3 places marked for holes but i made my own
other than that im looking foward to seeing how it comes :D!!
I agree with the four. If you dont do four the panels will bubble and they will look like CRAP!
When you get pictures up, send them to Ken and he'll post them on his site. I have the same fairing and the same fit-up problems that you described. My exhaust started turning my lower brown so I wrapped the exhaust w/ header-wrap and taped some heat-shield on the inside of the fairing. Here's a picture of mine in the intro post. Glad to hear others are having success w/ Ken's fairings.
http://forum.svrider.com/index.php?topic=55033.0
Yeah man your bike is sweet. I like it a lot. I am going to heat shield the lower to stay away from the browning. No need to wrap it though i heard. I already talked to Ken because my bike was a naked before I started so he wants a write up to know what my issues with wiring an S panel into my naked wiring. PRETTTY much the same except a couple wires are different colors etc.
I alrady drilled holes becaue I put stockers on to mount up the body. Why what is so different? I know you originally used stockers then put yours on.
well
this may sound really weird.... when i put the gsxr mirrors on, i had to make new mounting holes in the fairings ken sent me, but they lined up with the new windscreen and bracket holes, i guess because the screws arent going in 100% straight.. you may have to mess with the holes a bit if u decide to goto gsxr mirrors, or maybeh not, just look out for it..
Thanks. By the way are you going to the Rally?
i really really want to, i gotta figure out a way to get my bike there, im definately not riding to nc from florida, ugh
i tried to rent a truck and they wanted like, $.98 a mile, rofl
1 - 10 of 10 Posts
