Can someone please explain to me exactly how to blip the throttle (rev match before downshifting). I understand the concept, match the revs to where the engine will be once the clutch is released to the lower gear thus not interrupting the engine and possibly locking up the rear wheel. The thing is, the exact mechanics of it, when to EXACTLY release the clutch and how much to blip it is what I am unsure of. For the sake of semantics - and please correct me if I am wrong - but all "blipping the throttle" means is cranking the throttle a fair amount to increase the rpms - am I correct in this?
There are several ways to go about it and I am not sure which is right -
1. pull clutch - downshift - slowly give gas as you slowly release clutch. This is more of a blending of more gas as the clutch is released.
2. blipping the throttle (which I understand the concept but not the practice) - What I have been doing and I assume its wrong: pull clutch - downshift - blip throttle and wait till revs calm down (which I know probably defeats the purpose) and the release the clutch.
The issue I have is when EXACTLY do you release the clutch? If you do it WHILE you blip the throttle then the bike will jerk forward. If you release the clutch AFTER your are done blipping the throttle then by the time the clutch is release, the rpms you gained by blipping are largely erased. I know I am doing this wrong but would appreciate learning how to do this correctly. BTW, this topic has not been raised at all in any of the advanced riding classes I have taken.
