Somehow the plastic part that my clutch cable is encased in got pulled put of the engine cover, causing the cable itself to be exposed and break. When i had a new cable put on, the mechanic said that I'm almost completely out of adjustment at both the clutch and at the handlebar. The mechanic said some bikes you can reset the arm that the cable attaches to at the clutch to give you more adjustment on some bikes, but he couldn't remember if you can do it to the SV. Do you guys know if you can move the position of that metal arm to give more adjustment???
