1 - 4 of 4 Posts
I went to put on some swatt clip ons with 1.5” risers, and was wondering how other people remount the brake reservoir. It looks like maybe I could get a longer bolt from the hardware store, then use the stock bracket, then bolt it to the risers? Would this work? Or what else should I do?
I'd seen a pic somewhere (maybe here) that had the reservior bracket turned and then it was installed onto the bolt that clamps the brake lever to the bar (not sure if it was a longer bolt or stock). Looked like it would work just fine, and is what I'm going to end up doing when I do my S=>N swap.
Build a bracket and use a triple bolt
check this out from my 09 Suzuki SV650s. just straighten the bracket out with some heat and get a little more 1/4" fuel line.
58402
58403
58404
1 - 4 of 4 Posts
